2015 Bravia Android TV Issues
NickCo1979
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
6,373 REPLIES 6,373
profile.country.IE.title
EggDublin
Actually, they do have AC cards in them which given they didn't put in a decent ethernet card in is suprising.
I connect to my AC router at between 500-600mbps - the router is about 8m from the TV.
I configured the router to be AC only in the 5mhz band and gave it a different SSID so the TV always connects via AC. It works much better than the ethernet connection if you are trying to stream from a NAS.
pamorri9246
@cswalmsley
I've got an older Sony TV (not 4k) and it's connected to my 5.1 amp via hdmi, but I need to press the sync menu button on the remote to swap between sound from TV or amp, select "Use audio system for audio output". Worth a try to see if that fixes it.
profile.country.ES.title
kaplox
Does someone know if there is a plan to upgrade our Android TV to Marshmallow 6.0 version? Have lots of features, several specifically designed for TV.
Regards
In 99.9% of cases ethernet will be faster than wifi. Even on an 100Mb nic.
Even if these Sony TVs had AC wireless cards, which I doubt, ethernet would be faster in most cases.
They do have ac
andrewsoong
I am shocked.
Anonymous
Not applicable
@andrewsoong wrote:
I am shocked.
Did you get the AC and DC mixed up. Bzzzzzz.
Sorry couldnt help it.  :grin:
malcolm1962
Could you explain why a wifi router configured this way works better than the Ethernet connection? I have my Bravia connected via Ethernet to a gigabyte router, same with my NAS. Why would getting even 600 mbps via wifi be better?
elraouk
Gigabit switch / router / cables mean nothing if the TV's ethernet port has a max 100mbps
Did people find a fix/workaround for the "Scene: Full" popup in 3D?
A second thing.. if I enable surround/Audio passthrough in PLEX, I cant play a single movie. it just tells me that the connection isnt fast enough for streaming (Im connected directly to the router and nas using Cat6 cable in between) and do I turn it of, the movie starts within a secound without any buffer issues?
wills_b
Whilst 500mbps wifi is numerically faster than 100mbps Ethernet, in my experience Ethernet is generally a lot faster and more stable a connection. Haven't tried AC on the TV so can't comment but I won't be rushing to jump over to wifi in a hurry.
