At present I'm getting a message that lens is not correctly attached and can't activate the shutter.
just go to the set-up menu and scrol down to "Release w/o lens" and set it to "Enable". Then you can use any lens with matching adapter in A or M mode, no AF.
Have fun with the pinhole!
That works. Many thanks.
