Z5 Premium not turning on
BlazeAwesome
My Xperia Z5 Premium won't turn on.
I've pressed and held the power button. Didn't work. The hard reset is not working. I tried pressing the off button near the SIM and tried turning it on again. Didn't work.
Also when i hook it onto the charger the notification light doesn't light up. PC Companion isn't recognizing it either.
Please help!
profile.country.RO.title
_alexdon_
You need to contact your Local support in this case. I am sorry.
alexdon
51 REPLIES 51
_alexdon_
See if you can perform a software repair using PC Companion.
alexdon
Jake-SonyXperia
Champion
Hi BlazeAwesome,
Welcome to the community,
Before attempting the software repair try the following.
Hold the power button and volume + key for around 15 seconds, once done immediately connect to a charger and keep it on for around 1 to 2 hours.
See if you can power the device on, if no follow through with the provided instructions.
BlazeAwesome
Thank you alexdon and Jake.
Jake, I tried what you said but it still is unresponsive. I'll go ahead with what alexdon suggested.
Thanks.
Tags (1)
_alexdon_
Keep us updated.
alexdon
BlazeAwesome
I've reached the part where I have to make sure my phone is turned off and connect it to the PC. I'm sure the phone is turned off but it doesn't proceed to the next step.
_alexdon_
Can you try to charge the device for 2 hours before trying this?
alexdon
BlazeAwesome
I'll try that and get back to you.
BlazeAwesome
Still not working.
_alexdon_
So turning the device off, starting the repair process and connecting with volume down pressed doesn't trigger the repair?
alexdon
