hi,
im living here in UAE..,
when i go to philippines for vacation someone stole my x-peria z2 is it possible to lock my x-peria and nobody can use it again.?
please help me.. i use it only for 3 weeks..
HI findme,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
With the information supplied, I can advise that this can be done using My Xperia, however you would have needed to turned this function on when you received the device. Try navigating to the following website and log in to see if you can use the service.
https://myxperia.sonymobile.com/
i hope this helps
HI findme,
i hope this helps
If you encounter problems with myxperia,use google device manager.
Hi
I use to follow all your advise, but it shows nothing..
anyway thanks for cooperation.
more power..!!
