how to open popup "what to use"
ramax
I want to change the melodies for the call and the alarm clock. Previously, a popup appeared with a choice of applications. Once, I chose "always" in the popup and after the popup does not open. How to open this popup again with minimal losses? Android 7.1.1
ramax
You need to go into the application "Media Storage" or "Select Music" and remove the default settings
ramax
