Advertisements in start up screen.
Chromaphyo
Sinds the last system update to build 32.4.A.1.54,  I am having ads in my startup screen.
This has never happened before.
The ads seem to be generated by Google,  and no matter what changes I make in the ad-settings, or the various app-settings, they won't go away.
I think that I have tried just about everything that I can think of, apart from a complete factory reset. I was hoping to avoid that.
Suggestions anyone?
9 REPLIES 9
ChloeS
Contributor
Hi @Chromaphyo
Welcome to the community!
Sorry to hear about that, can you show me a screen shot of the adds you are seeing so I can help out? Slightly_smiling_Face
Chromaphyo
Example 1Example 1
Example 2Example 2
@ChloeS
Thanx for your response.
The adds are nothing special as you can see. They are exactly the same as the ones that I get in various free apps.
What particulary annoys me is that I have to work my way through one, before I can even use my phone.
Uliwooly
@Chromaphyo
That seems to be a third party app acting up, try this
Boot in safe mode and report back, if you don't experience the same issue then it is indeed a third party app causing this.
Chromaphyo
@uliwooly
I have booted the phone in safe mode and I haven't seen the adds while in safe mode for several hours.
If you are right, and it is a third party app, then I have to find out which one.
Is there a quick way to go about this, or is it just working my way through every  app one at a time and see what happens.
Uliwooly
@Chromaphyo
There isn't a way to figure out the culprit BUT you could open the app drawer > menu > sort apps > by date
that way you can start uninstalling the newest apps first
Chromaphyo
@uliwooly
That is what I am going to do. It is going to take me a few days because the adds turn up at irregular intervals.
If this fails then I am going to reset the phone.
Thank you for your input.
Regards, Geert (chromaphyo)
Uliwooly
@Chromaphyo
Don't forget to share which app was causing the issue so other users could take advantage of the info
Chromaphyo
Sorry, my bad...
I started to remove the apps one by one, as suggested.
The adverts stopped appearing after the removal of KALENDER +.
I have replaced it by another scedular app and I have not seen any more adds in my startup screen,  and maybe I am just imagining things, but I am thinking that I am seeing less adds overall.
Thank you for your help.
Regards Geert. (Chromaphyo)
Uliwooly
@Chromaphyo
Anytime
