32.4.A.0.160 (7.1.1) is on a roll _updated users can leave a feedback on performance nd battry
pravi
 _anyone who has updated to this build can leave ur thoughts on device and battery performance (still lags? Heat?) soo other users can decide whether to go for it or not (; thanks!!
          ##As per the info I hav##
_image processing has been fixed (not totally..  but btr than previous build)
_Cal log is still laggy
_like x series... we got Xperia assist!
 _5 cores r informed to be active!!
118 REPLIES 118
Martin20
Image processing is much much better but to me still doesn't seem to be as quick as on MM
Also seems like all 8 cores are enabled.
More things to follow
ezy2ezy
Contributor
i really hope the WIFI issues have been fixed.... that should help the battery
and any sign of google assistant?
pravi
All 8 cores? That's insane!!  It Wil gonna fryup the device!! I blv 1-2 big cores can do btr along with smaller 4 cores (that's what devs did back in MM and nw on 7.1)!!!  Can u share a screenshot  to drive amd drop a link here?
NeoBeum
Enthusiast
lol
I think I might flash it on to my other device and see how hot it can get
NeoBeum
Enthusiast
There's no major changes as expected, but the first start setup UI has had a revamp.
Screenshot_20170524-064744.pngScreenshot_20170524-064750.pngScreenshot_20170524-064806.pngScreenshot_20170524-064813.pngScreenshot_20170524-064822.pngScreenshot_20170629-000105.pngScreenshot_20170629-000112.pngScreenshot_20170629-000120.pngScreenshot_20170629-000129.pngScreenshot_20170629-000142.pngScreenshot_20170629-000151.pngScreenshot_20170629-000201.pngScreenshot_20170629-000720.pngScreenshot_20170629-001437.pngScreenshot_20170629-001451.pngScreenshot_20170629-001458.pngScreenshot_20170629-001700.pngScreenshot_20170629-002900.pngScreenshot_20170629-003521.pngScreenshot_20170629-003608.pngScreenshot_20170629-005531.pngScreenshot_20170629-005536.pngScreenshot_20170629-005540.png
8 Cores are active
and Tips has been moved to a new menu entrywith  a Short Cut to Stamina Mode settings
Blueooth icon a lighter shade of blue, but the crappy overlay is still the same Slightly_frowning_Face
I have 8 cores running on 7.0 normally
quick launch has 6 icons now, but still doesnt make up for the toggle changes from marshmallow
martinmrmus
Contributor
Are missing translations fixed?
Dim_Darlyng
Hello, I, an E6833 user, can still play no 4k vidéo on YouTube. The 4k option on YouTube and does not even appear to select on YouTube app options...
CABK242
Your Recent update really slowed downed my Z5 premium. It's not even a month old
DeepeshT
Bluetooth still doesn't display metadata nor the controls of the Bluetooth device are able to control music app of the phone. This was working fine when the phone was running Marshmellow. Sony Support has not at all been helpful in analysing the issue instead copy pasted some old information they were provided in the past.
John B: Can you please confirm the build number of Android you are using please?
Deepesh: Android Version - 7.1.1 Build Number - 32.4.A.0.160
John B: For the Xperia™ Z5 this will be fixed with software version 32.3.A.0.378 / 32.3.A.2.33
Deepesh: Isn't it that I am running a higher version that what you are recommending?
John B: That does not seem to be the case
Really???!!!!
