отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
Red stripes on the photos
РЕШЕНО
helulu
Посетитель
Hello all, when I use camera menu mode on my new xperia xzs at high shutter speed (250-1000), there will some red stripes appears on the photos, how can I fix it?
1 УТВЕРЖДЕННОЕ РЕШЕНИЕ
Утвержденные решения
Lord_viridis
10 ОТВЕТ 10
profile.country.US.title
Qatrium
Hello @helulu and welcome to the community!
It would be really helpful if you upload a sample photo so we can figure out what's the issue, along with all information about software version and camera mode.
helulu
Посетитель
Hello, thanks for your reply, below are the red stripe photos
Qatrium
@helulu
This looks strange, are you sure there is nothing stuck to the lens? No badly fitted glass protectors or cases? Were these lines showing since you ever tried this shutter speed or they just started appearing lately?
helulu
Посетитель
Hello
I'm sure nothing stuck on the len, the red stripe line no just appear on the photos, when I take photos , it also appears on the screen, but only in higher shutter speed with dim environment.
helulu
Посетитель
Hello
I just found that the red stripe just appear in the low light environment and the red stripes like a scanning line those running on the screen.
Lord_viridis
It's light phase beat, a common problem with cameras and fluorescent lighting.
I'm assuming the lighting was fluorescent?
To fix it, higher iso or manually adjust shutter so it disappears
Lord_viridis
https://en.m.wikipedia.org/wiki/Fluorescent_lamp
Look under disadvantages, then flicker problems
helulu
Посетитель
Hello
Many thanks for your helps
Matteo_An
Посетитель
Do you know what is the problem with my XZ Camera pDo you know what is the problem with my XZ Camera p
