- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Phone dialer bug
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same problem. It goes without rebooting. You have to take a call, and then it goes.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am also facing the same problem where my phone dialer stops responding and the screen goes black. I have to go to the phone dialer app in settings to restart it multiple times. This has been happening ever since i upgraded to android 7. Very annoying!! I am not sure if Sony is aware of this issue or not.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
try to perform a software repair using Xperia companion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Whenever i dial a number my screen goes black and doesn't respond. Its so frustrating to see this happening when u want to make some urgent call and u cant even call up the person. Can anyone help?
I reboot my fon after that amd only for the first time i could dial any number from my caller list and then again the dailer doesn't respond.
Help needed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
does this happen when you are on safe mode
try to perform software repair using Xperia Companion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @RahulSharan,
Welcome to the community,
Is it when you connect a call the screen goes black? I would recommend that check that you don't have anything like a screen protector blocking your proximity sensor. You can see where the sensor is located in the picture bellow. It is number 7.
You can test how your sensor is working if you go to: Settings > About phone > Diagnostics > Test > Proximity sensor.
I'd also recommend that you as @nolramlb suggested your try and reboot your device to safe mode to see if this may be caused by one of your downloaded apps as they will be temporarily disabled in this mode.
Let me know how it goes!
