I'm very sorry to hear that
I've been testing this here but i've been unable to replicate this on my phone so far. Would it be possible for you to take a log from your phone after you have tried to use tap to wake without success and send that to me in a private message?
To do this:
Settings > About phone > Build number, tap 7 times on the build number
Go back to Settings and select Developer options and turn on "USB debugging". Then tap "Logger buffer sizes" and set this to "4 M".
- Turn off display and then try to double tap to wake. In case it doesn't work, turn on display by on/off button and then:
Settings > Developer options, select "Take bug report". When the report is ready (may take a minute or so) you get a notification that you can tap and share to Google Drive. Please send me a link to this file in a private message.
I have the exact same problem! I even did a factory reset.
Stamina Mode is off all the time.
I have to press the screen multiple times and hope that the screen lits up somehow.
I heard that someone had it fixed after switching for a new device with the same software Build number.
Also saw some people having the same problem on XDA.
So is it a hardware issue or software?
If it's a hardware issue, I will need to bring the phone back to the store as i just got it few days ago.
