- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Call and SMS notifications won't play
My phone won't play any notifications when I receive a text, neither will it play any ringtone when someone calls. It works well after a reboot, but only for a few minutes. I tried a hard reset and even factory reset but the same thing happens, it'll work for a few minutes and stop eventually . I have Checked all the settings to make sure notifications are turned on.
Please help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks @Quester.
My phone is currently running in safe mode, I'll have to observe for a few more hours.
But what next when I find that the notifications continue/discontinue to play in safe mode?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If the issue disappears in safe mode, this means that one of your installed apps are causing it. As safe mode will disable all 3rd party apps. You'll have to figure out which app is acting up by uninstalling one app each time and testing (tedious), or by performing a software repair using Xperia Companion and re-installing your apps one by one.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Mebs wrote:My phone won't play any notifications when I receive a text, neither will it play any ringtone when someone calls. It works well after a reboot, but only for a few minutes. I tried a hard reset and even factory reset but the same thing happens, it'll work for a few minutes and stop eventually . I have Checked all the settings to make sure notifications are turned on.
Please help
Okey, check this path
Settings>Apps
1st click on 3dot icon and select "show system"
Now, click on gear icon and go to advanced category and select "special access"
Now click on "Do not disturb access"
See any app manage do not disturb function?
Now go to Settings>Lockscreen & security>Apps with useage access
See any third-party apps (no system apps) is listed and permission activeted?
If yes, turn one of them and test the problem is solved? If no check other one and...
If notification solved, means you find the app break your notifications.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@ Quester I at least have established that a third party app is the cause.
I haven't however managed to find out which one it is exactly.
But thank you very much.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@GenomeX my phone says "no installed app has requested for do not disturb access"
Also I have toggled the settings under 'apps with usage access' and the notifications still won't play
