Dead Trigger and Temple Run issues in ICS Update
neo_kalyan
Can anyone confirm if Deas Trigger and Temple Run are working with the new ICS Update? In Dead Trigger, the floating touch is picked up by the app and also the buildings look black at the mission selection screen. Temple Run is also not picking up the touch gestures correctly. If there is a fix, please let me know.
7 REPLIES 7
Not applicable
Don't know about dead trigger(as I dont play it), but temple works just fine as it was on GB. even new glove mode is working properly here! Edit: I read the about dead trigger on google play page and they say game wasn't tested on sony ericsson devices, maybe thats why you are having issues
neo_kalyan
I have reinstalled Temple Run and it works fine now. But Dead Trigger used to work fine on GB. Now, it picks floating touch. Can you or anyone please install and confirm if it is working for you... it's free too.
Not applicable
Yea, its free, but not available in my country.
Patroxx
yup even i am having problem with dead trigger ... everything goes white ... and ma Reptide GP 1.3   is not workin on ics Slightly_frowning_Face
Not applicable
I tried to download Dead trigger and i have similar issue, all buildings are black and floating touch is enabled. Anyone have solution?
abhig10
I too have the same issues on my sola with Temple run, Dead trigger and Frontline Commando. Hopefully sony will fix this in the next update (if it comes).
profile.country.MK.title
Epperson45
Hi!
Some users have reported similar issues with Temple Run and Dead Trigger on the ICS Update, mostly related to touch sensitivity and display glitches. A quick workaround for Temple Run is to try the unblocked version online, which often resolves gesture problems and ensures smooth gameplay without installation issues. You can check out temple run game to play directly in your browser, dodge obstacles, and enjoy the endless runner experience even if the app isn’t working properly on your device. This version is convenient, especially if you’re facing problems with updates or device compatibility.
Hope this helps and happy gaming!
