Xperia X won't install nougat
xoFG
I keep getting a notification that I need to download and install the new update, but I can only get as far as downloading it. When I click install my phone restarts and I get a rectangle with a warning symbol inside and the notification says unable to install. There is no explanation why, anyone else getting this problem?
5 REPLIES 5
profile.country.PH.title
MarlonUk1
try to upgrade using the Xperia Companion
xoFG
Technophobe here.. What's the Xperia Companion?
MarlonUk1
you can upgrade your device via the computer, by installing Xperia Companion
http://support.sonymobile.com/global-en/tools/xperia-companion/
it is simple to use, just connect your device to your PC and run the program
xoFG
Brilliant, thank you so much!
DonFrankLin
I'm having the same problem. I'll give the Xperia companion a go. Thanks nolramlb
