Status bar sometimes hiding, only reboot help
SirRobin
Contributor
Hello Slightly_smiling_Face
On my new X Compact with stock german FW, the navigation bar sometimes hides and i can only see the bar when swiping over the screen...only a reboot brings it back. Is this a bug? i canĀ“t find any setting for that option...
Thank you Slightly_smiling_Face
GruƟ Sir Robin
--> KD-55XE9305 --
Jonas
Master
Hi again!
I have received some more information about this, and what @Alessio_84 wrote is very correct, thanks for helping out! Slightly_smiling_Face
The easist solution is to disable Google Now.
1. Long press on an empty area of your application Home screen, then click Settings.
2. Find Google Nowā„¢ and disable it.
3. Reboot your device.
Let me know if that helps! Slightly_smiling_Face
10 REPLIES 10
Jonas
Master
Hi @SirRobin,
I'm sorry to hear about that. Slightly_frowning_Face
I want to make sure that I understand your question correctly. Slightly_smiling_Face
You are referring to the soft keys (Back, Home and Task) at the bottom of your screen, is that correct?
These should not be hidden unless you are using an application that hides them, for example bringing up a YouTube video in full screen.
How often would you say they are hidden, is it a few times per day or once/twice per week and when they disappear, are you using a specific app or a service prior to this happening?
I would recommend that you reboot your phone in safe mode to make sure that this isn't caused by a thirdparty application, to exit safe mode simply restart your phone!
Let me know how it goes! Slightly_smiling_Face
SirRobin
Contributor
No, sorry, i think my information was not enough.
Not the soft key buttons at the bottom, i mean the status bar at the top of the screen (wifi/battery/bluetooth/nfc/etc).
GruƟ Sir Robin
--> KD-55XE9305 --
Jonas
Master
Oh, I see. Slightly_smiling_Face
The same goes for the status bar, there is no setting in the phone to hide this bar, you can only choose what should be displayed on the bar, not remove it completely. So I would recommend rebooting your phone in safe mode and see if the status bar hides itself when third party applications aren't loaded.
Keep me posted! Slightly_smiling_Face
Alessio_841
Contributor
Hi @SirRobin,
The cause of your problem is a bug between the Google app lastest update and the Sony's Home launcher. Yhis bug affects also the change of buttons of the navigation bar that don't change according to the theme but remain stock by Sony.
To solve the problem you can disable, in launcher settings, the Google Now pane or totally disable the Google app if you don't use it. In this way the status bar reamins always visible (except in the drawer).
Jonas
Master
Hi again!
Prince13
Doesn't even need rebooting. Just disable Google Now, which will make it roll back to the factory version, then enable it again.
I'm not sure what 'updates' I lost in this process, but I sure wasn't about to add yet another swipe just to turn my mobile data on! (which btw, still needs another extra press after this ridiculous Nougat update... šŸ˜­)
Jonas
Master
Hi @Prince13,
Thanks for helping out! Slightly_smiling_Face
Regarding the extra click to enable or disable mobile data, I'm afraid at the moment there is no other way to do it, and I understand it's not optimal having to use another press.
I thank you for your feedback regarding this and I will forward it as user feedback! Slightly_smiling_Face
Prince13
Thanks @Jonas. I already contacted customer support directly regarding that issue, and also the awful image enhancement bug (which takes 10 seconds in the Album app). If you and your team could also pass these on to thr relevant development team, it would be great. They haven't been fixed in the last update, so hopefully you can bring it to their attention for the next update.
Jonas
Master
You're welcome! Slightly_smiling_Face
I will make sure to let them know about the Album application as well and I thank you for telling me about this! Slightly_smiling_Face
Let me know if there is anything else and have a great day!
