Hi everyone
Execuse me for idiot questions
I accidentally removed completely IMEI label tray.
Can it damaged my device?
Sony tested this situation?
Thanks in advance for replies!
It could void the warranty, but only your local Xperia Care can answer that question, as for functionality it shouldn't, as long as you are able to firmly close the flap/cover.
The main question is can this label damage the plastic/metal part where he was mounted when I pull it out?
the plastic label itself was torn from the edge where it was fixed
