- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Apps moved to micro SD-card not available when USB-device is connected via OTG ?!
Hi everyone,
I have read that the micro SD-card will get deactivated once a USB-stick or -HD is connected via OTG. Is this true? Can this be behaviour be changed? Would this be different if I installed AOSP on the Z4? Thanks a lot for your help! Using SD-card and external USB simultaneously is vital for me as I need to copy photos from an external stick / SD-card to the tablet's SD-card for backup-reasons. Thanks again and best regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I just tested it here in a Z4 Tablet and you have access to internal storage, the SD card and the external USB-drive at the same time.
I can't remember hearing of what you describe on any of our products actually.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Rickard,
thanks for your reply. I must apologize, my description was not very specific.
If you could have a look especially here:
http://forum.xda-developers.com/z4-tablet/help/usb-support-t3151411
and here:
http://forum.xda-developers.com/z4-tablet/general/usb-otg-support-t3147871?
Users describe that, in case apps have been moved to the SD-card, once a USB-device is connected via OTG those apps became inaccessible. In some cases (apps try to run in the background) a crash of the Z4 is reported.
Someone is even quoting a reply from Sony support according to which the SD-card is meant to unmount on OTG-connect.
Could you possibly test / confirm / deny this?
Thanks a lot for any hint and best regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I see. That is something i have heard of (it's been reported here on our forum as well) and it has been forwarded internally.
But as i understand it, it's not when you connect the USB-drive it may happen. It's when you then disconnect the USB-drive.
If this happens for you i can at the moment only recommend that you don't move apps to the SD card. Z4 Tablet has about 20GB of available internal storage so i think in most cases it's not needed. Also note that moving an app to the SD card only moves the apk-file and not other data like obb.
In case this has happened, try restarting the tablet.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Rickard,
Any idea whether this behaviour might be different when installing AOSP and/or using the Link2SD-app (so apps are not moved to SD but rather linked to a 2nd partition on the SD with ext4-formatting) ?
Thanks again!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm afraid i don't know how this works in AOSP or with Link2SD. They require unlocked bootloader/root access.
But it has been forwarded internally and i will let you know as soon as i hear anything.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Rickard,
thank you for offering further information and for your great and fast support on this!
Best regards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi I'ma owner of a z4 tablet and i got these problem - i've try different microsd cards kingston and sandisk and I got the problerm if an OTG cable ( tryed different cables) is mounted, - the apps on sd card are not available and even if I disconnect. It needs a restart to brng them back on screen.
Further I reset my Tablet to factory two times but the problem remains.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Has this problem been fixed? I want to use the z4 tablet to process pics from my DSLR without hauling a laptop between continents, so a USB card reader would be the thing.
