WH-CH700N bluetooth headphones
RISOLTO
brblake61
Esploratore
Can anyone tell me if I can buy a longer headphone cable from Sony, as the one on my very old pair of headphones is about twice the length? If I can where in the UK can I obtain one from please? Thanks for your help.
1 SOLUZIONE ACCETTATA
Soluzioni accettate
Vanilla_
Collaboratore
Hi brblake61,
I've checked this for you, and I can see that the length of the supplied cable is 1.2  meters. It seems that there are only replacement cables of the same length and specifications as this is the one recommended to use with the headset by Sony.
Vanilla_
5 RISPOSTE 5
EdwinaU
Moderator
Hi there,
Welcome to the community.
There is a spares parts page with a cable for your product here. Please take a look and see if it's suitable.
Best wishes,
Ed
brblake61
Esploratore
Hello Ed,
Many thanks for the information and for the welcome to the community.
I've been onto the site, but unfortunately the length of the cable is not given.
As I've (foolishly!) already bought one cable through Amazon, which doesn't work, I'm loath to buy another "blind".
Kind regards,
Brian
Vanilla_
Collaboratore
Hi brblake61,
Vanilla_
brblake61
Esploratore
Hello Vanilla_,
Many thanks for the information.
It looks as if I will have to forget trying to buy a longer cable and sit nearer to the CD player (which sadly, isn't bluetooth enabled.
Brian
Vanilla_
Collaboratore
Hi brblake61,
I understand where you're coming from. I wish there was any other alternative. But I'm pretty sure that using a longer cable with the headset might not provide the same audio quality or might damage your headphones in the long run. So it's better to use only the recommended one.
Best wishes,
Vanilla_
