NW-A35
Bubdee52
NW-A35
Hi, I am the new, proud owner of an AW-35! works fine, great sound quality but I can only use it in my car by connecting through bluetooth. I'd like to have it hard wired to keep it charged and I believe the sound quality would be even better. It works through the aux port in the car but I dont get any of the function controls on the steering wheel. If I use the usb port it the car doesn't see it at all.
Any suggestions or support greatfully received.
Best reagrds,
Roy
IamNic
Hi @Bubdee52,
can you charge it while having it connected via bluetooth?
From what I understand during bluetooth connection the player streams the file directly as digital signal instead of giving your cars stereo an analog signal like it does if you connect it via AUX.
So i doubt you would get any audio improvemend by using it wired. Also you miss out on the controls as you already noticed.
My recommendation is to continue to use it connected via bluetooth.
- Nic
