HI
I have a NW-A35 which will not control the volume when used with bluetoth speakers. I've tried three brands now, including Sony's own SRS-x11. Still no control over the volume from the walkman.
Please help, this is driving me nuts
Regards
Thanks for the suggestion, It now works perfectly but only with the Sony Speakers. If I connect up the JBL or Bush speaker it works fine for the first connection including the volume control, but if I disconnect and reconect to any of the speakers it stops the volume control working again. Most strange. Oh well, I'll just have to use it with one set of speakers.
Thanks Again
that only depends of the speaker of manufacturers and not the walkman.
So you can face that issue that's normal. But what's not normal is that you can't control it over sony speakers. I can do it with my A35 & X11... try to reset the walkman to see if any changings?
Thanks Again
