windowsformsparking
Lizzie
Besucher
windowsformsparking
Anyone know about this? i get it sometimes when i shut down. it seems to be related to after and when i get a low memory message. i try to do too much in one program and my puter can't handle it sometimes and also i probably have too much other stuff open at teh same time.
anyway i did a google and there wasn't much, it was mentioned on those forums where you post a hijack this log. i did a log and i didn't see anything unusual. the one thing new as such is my external harddrive, its a Maxtor, it may be related to that. the windowsformsparking on some of the forums was related to a HP printer.
before i go and post a log somewhere, has anyone any hints or ideas or what exactly causes windowsformsparking.
thanks.
:slight_smile:
19 ANTWORTEN 19
profile.country.en_GB.title
kee-lo_
Mitglied
Hi Lizzie,
I'll check my Maxtor for that - maybe it's the program which parks the heads of the hard disk?
I know what you mean by overworking your VAIO, I'm guilty of that
Lizzie
Besucher
That’s the thing I don’t have a HP printer, the only external thing I have is my external Maxtor harddrive, so it obviously involves an external device.
Lizzie
Besucher
I should have said, it comes up as that message you get when a program doesn’t shut down properly and you can either click end now, cancel or wait for it to shut down.
Thanks!
:slight_smile:
Thalamus.
Champion
I have read that this has something to do with HP printers as you stated. I noted that goto msconfig and disable hp image zone fast start (hpqthb08.exe) this may help. Not sure though! Do you have a HP printer, if so maybe they have a solution!
kee-lo_
Mitglied
I don't seem to have that process and I have that same drive
Lizzie
Besucher
i found more on google under 'windowsformparking' (drop the s after form)
one place suggested it is a "a useless idle program which sits in the background sucking memory."
i've posted a thread and i'll let you know how i get on.
Thalamus.
Champion
I been googling and found references to windowsformsparking. Sadly :slight_frown: no definitive answer though!
The solutions generally seem to be using msconfig & unchecking items manually. You said you recently added a maxtor external drive maybe this has caused some form of conflict.:smileysad:
Sorry I can't help more :thinking:
Lizzie
Besucher
i have the maxtor a few months now. i'm going to do a hijack this log on one of those forums and see what they say.
thanks very much for your help. :slight_smile:
Thalamus.
Champion
Good Luck :slight_smile:
