I recently purchased a vaio A series notebook, for the first week or so it was running silent, now it seems to run the fan constantly from the moment it is switched on. Does anyone know why this might be?
The VAIO should be ACPI compatible. If so, the fan is subject to sftware control. Sony should fix this...
I spoke to sony about this and they said the following...
CPU usage above 60% is bad
They would ask you to restore your pc to factory settings...and then do some diagnostics....
I still just want to clean the heat sinks....im going to wait til the gauarantee has expired and take off a cover... is this wise?
No, that is not true. My father's Samsung Notebook is a Pentium M 1,5. the fan is running only when the unit starts up. Other then that it is completely quite with normal office software running.
am having the exact same problem. The fan is running very quiet, but still it is running. This shlould not be on a centrino notebook. Does anybody have the same problem
yes i have the same problem
i have lap top grt915m
i have seen this on all the grt series... that fan just wont stop running...
specialy on the one with the gforce 5xxx go graphic cards. if you can see how that card is build in you would understand why that fan can't stop blowing. i have also noted one other thing... the noise that you hear is mostly created by the air-flow... not buy the fan itself.... the fans that sony uses are of very good quality... compared to some other fans that i have seen.
i am not a gamer... so i don't need that gf5600 graphics card... but i wanted a 16 inch display and at that time there was no other model with that size and a smaller graphics card... if at all possible i would love to throw that card out and replace it with a gf420 or anything that reduces the rpm's of the center fan... the heatpipe fan runs very quiet and is bearly hearable.
now were could i get a detailed component plan for a sony notebook... if i asked sony they would propably tell me... "it would be a cold day in hell, before we reveal what parts are replaceable in a vaio".... now DELL... yeah those were the good old days... i called them up and they gave me a downloadable detailed plan of the notebook i had...
hmmmmmmmmmmmmmmmm
joe
I found out one thing: it is not the cpu fan that is running and that you can hear. I found that out when I entered the BIOS at startup (press F2 when the VAIO logo appears). After a while the CPU fan started. So there must be another fan in the unit. Maybe the Southbridge or the GPU...
there are 2 fans inside the notebook... and the one that is cooling the graphics card is the one that makes the most noise...
joe
Guys why do you get so stressed about fans?
If I don't hear a small fan sound I get worried about overheating.
Then again I have been using PCs for what, 15 years ?
I had a look. There is only one fan. It is the main CPU fan. This is subject to software control. So it is up to Sony to fix this issue.
