video/ audio from tape to DVD
oswaldsson
Is it possible to transfer video/ audio from tape created with a video Hi8 Handycam CCD-SC55E to a DVD in my desktop PCV-W1G? If so, HOW?!
10 REPLIES 10
profile.country.en_GB.title
kee-lo_
Digital or analogue?
oswaldsson
analog! Its a SONY camera from the late 90s...
hope you can assist an old man!
oswaldsson
kee-lo_
You need a capturing device which can connect to FireWire or USB2. Haupagge are usually good cards.
oswaldsson
Kee-lo!
many thanks for your help. Perhaps I can prevail further: the camera connection is a 14mm pin (yellow) into a socket for both audio and video. The PCV-W1G computer has firewire as well as USB connections. Which card from Hauppagge would be appropriate?
Best regards
Roger
reaper
hi
do you have an svideo connection on your pc ?????????
if so there might be a chance you can get a converter svideo in with three comp wires on it tht would save you haveing to buy a card
i have never seen or used one though im just guessing that there are wires like that
regards ben
robpaxton
I'm sure that the W! has both s-video and composite video in sockets. It is then easy to use Click to DVD to capture and convert the video.
kee-lo_
Argh, I thought you were talking about the V1 :slight_frown:
robpaxton
The V1 also has s-video & composite in ports.
Greg
You could also condier oinvwesting in a new Digital 8 camcorder that you link by Firewire (I think). That way you can record digitally for the future, but still play your older 8mm. It's a little bit more money, but you can pick them up pretty cheaply now.
