VPCZ12Z9E
Frequently crashes with the BCCode 117.
Message was edited by: HHN-19
Some questions:
Message was edited by: stephanius
1) VPCZ12Z9E purchased august 2010
Default System BIOS
i7 CPU M620
8GB RAM
LCD 1920x1080
2) NVIDIA GeForce GT 330M, driver version: 8.16.11.8880 (orginally installed)
3) Windows 7 (64bit) SP 1
Factory software reloaded by Sony in may 2011
At your own risk, you may wish to try the nVidia driver supplied with the VPC-Z13Z9E/X which has the same GPU as your VPC-Z12Z9E/X.
The Z13 has Version 8.16.11.9024 and may be worth a try? It should be installed in SPEED Mode and the download will need to be Extracted to show the Setup.exe.
Sony support do not applaud the VPCZ13 driver.
They recomend to have the computer sendt back, for a full reload of factory software.
The first reload was in May and make no change, the driver still crashes.
