sony vaio notebook vpcf12sie "morse code like" bleeping noises
profile.country.en_GB.title
moonraker55
Please see my previous post of 07/02/12 about this problem i am having.
https://www.sony.co.uk/discussions/message/739356#739356
Message was edited by: Blencogo
To add a link to previous question.
4 REPLIES 4
rich912
Contributor
Hi moonraker55,
A Google search will of course provide hits for beeping on Sony, or any other manufactures computer, as the BIOS will produce a Beep Code during ‘power-on self-test’ (POST) to indicate any hardware problems found. But as the sound is not being emitted from the speakers I doubt this is your problem.
My initial thought is that a cooling fan is faulty or clogged with dust as this would seems to be a mechanical noise.
I suggest that you download a free utility such as PC Wizard and let us know recorded temperatures for the CPU and GPU during normal use.
http://www.cpuid.com/softwares/pc-wizard.html
You could also try using a canister of compressed air (Air Duster) to clean the cooling vents. This may only be a temporary solution as disassembly could be necessary to carry out a thorough clean/fan replacement.
Rich
Go n-éirí an bóthar leat
moonraker55
hi rich 912
thanks for the advice,,,dust is a problem in my house even though i use a duster every 5 years!....seriously i will take your advice and let you know.
regards
moonraker55
flogger12345
Wow! All those beep codes, and it was just the dust that caused this. Nice to know complicated issues have the simpliest answer. http://imagicon.info/cat/12-13/vbulletin-smile.gif
rich912
Contributor
We don't know that dust is the cause at present - it  is just a supposition...
