Делитесь своим опытом!
I have a little problem with my sony vaio notebook. It is a PCG-FC601 and it freezes while playing divxmovies. i allready updated the viachipdrivers, graphicdevicedrivers, windows and the bios.
it doesn't freeze regular, sometimes i can play 30 mins movie sometimes it stops after even 1 minute.
any idea what i could be?
(i apoligize for my bad english)
Sebastian
I had the same problem but it is nothing to do with the computer. At least I don't think it is a problem specifically related to Sony Laptops. The solution to this problem is firstly to uninstall all DivX codecs that are on your machine then to download the latest codec pack, I usually use Nimo which you can get from divx.com or divx-digest.com. And install this with all the codecs, the main thing you want though is the ffdshow. Having done this I haven't experienced any freezes.
...but before updating the Codecs, you have to update the
- BIOS
- Via 4-in1 drivers
- ATI Graphics Drivers
After installing those three, DivX & Xvid are no more problem and my TV-Output works properly and is adjustable (by the ATI-Tool).
Hint for good TV-Output: A normal TV has only 520 horizontal lines. So if your Output seems unsharp, put the resolution down to 800x600 or 640x480.
Now I watch all my DivX on TV in best quality!!!
Never ever this happens to me.
I use mplayer under linux
Also, playing DVD, cpu load never exceed 40%
i had the same problem, i installed via 4 in1 drivers and the problem was solved
