i simply cant burn dvd,s
my friends have all told me its the easiest thing in the world
ive just gone thru a pack of 25 dvd+
using
NERO
DVD CLONER 3
and windows own burn dvd programme
it copies ok
it burns ok
but when it comes to playing the copy
every dvd player i have including my laptop diesnt recognise any disk being in the drive
i have a sony vaio vgna517B
apparently with a dual layer rw drive that can write up to 4 hours of movies on one dvd
ha ha
WHAT THE HELL AM I DOING WRONG ????
Hi Angus,
XP can't burn DVDs but I would expect Nero to cope - what version of Nero are you using?
Does the drive PLAY DVDs?
Have a look in Device Manager -> DVD/CD-ROM Drives. Are there any Yellow warning triangles? Does it say the drive is working properly? What is the installed drive called (who makes it)?
You may have a faulty drive but check everything else first.
i have NERO 8
yes i can play dvd,s (very well) with quite a number of players
the drive is a SONY DVD RW DW Q58A
and there are no yellow triangles
just noticing my dvd player is in the F drive
if i open properties to the pie chart
there is no free space
is this right ?
a friend of mine has told me this is a problem with vaio,s
is this right ?
This was a problem with the DW-D56A drive but is not as common with yours.
I suppose you have a few choices: -
1. Try a different make of discs. Avoid the Double Layer discs as these are very fussy about the player.
2. Try recovering your Vaio back to factory condition using the Vaio Recovery Utility (Drive C:\ only) as many of these problems are caused by conflicting software installed since purchase.
3. Buy an external DVD+/-RW USB drive - these are cheaper these days.
4. Replace the drive in your Vaio. Although you can buy a drive for £30 it is difficult to fit - the keyboard and palmrest have to be removed to get at the screws.
Not very attractive choices I'm afraid.
I would recommend the external drive - something like this one: -
http://www.ballicom.co.uk/not-shown-17/samsung-usb-dvd-rw-retail-20x--replaced-by-samses224qeubn.p44...
