Hi my vaio fx 804 dvd cdrw player has recently decided not to work properly. When i try and play a dvd the video and audio play too slow and everything i have tried does not seem to work. Any ideas how to cure this annoying problem.
That's a weird problem and not one I've seen before. Have you tried uninstalling/reinstalling the DVD player software from the recovery disk(s)?
Yeah because if it was a bad drive they'd probably not play at all.
But..............
Hi ,
Have tried re installing still no luck. My DMA is active also. Any other ideas? Thanks
The only thing that I can think of is that someone has set a "Play in" time.
Search the WinDVD help for "timestretching" and that should tell you how to check the setting is correct.
I didn't know you could timestretch :smileythinking:
If it doesn't work after changing the timestretch setting then try using Videolan - I've just discovered it and it is V good. See the topic in the Third Part Software forum.
Dave, watching DVD's at high speed can improve some movies no end
Specially fight scenes
