please i need a revovery cd for the above model of sony viao laptop. it first displayed a blue screen then i tried restoring it didnt work then i tried restoring the c drive and along the way it came up with a prompt which says programe encounted a problem. now its shown me operating system not found. HELP!!!!!!!!!
Hi tabaknox and welcome.
Have you tried this: -
Reset the BIOS default values -
1. Turn on your VAIO.
2. When you see the Sony logo, press F2 several times.
3. You will get the PhoenixBIOS Setup Utility window.
4. Press F9 to get default values and then press ENTER to confirm.
5. Press F10 to save changes and exit and then press ENTER to confirm.
6. You have restored the default values and your VAIO will now restart.
Running the Recovery Centre from your hard drive: -
1. Turn on your VAIO. Make sure you are connected to mains AC.
2. When you see the first Sony logo, press F10 repeatedly.
3. This should start the Recovery from your HDD
4. In the Recovery Centre choose 'Complete Recovery' and follow the on-screen instructions.
5. Do not interrupt the installation even if it seems to have stopped - it may take some time.
6. Run Vaio Update and Microsoft Update
7. Reinstall your own data and software.
Good Luck
