on support site there isnt 64 bit driver for pointing device on VGN-FW21E with windows 7 64 bit.
If the Windows 7 driver is not supplied then Sony must think the Vista driver works OK. 64-bit does not appear to be supported for your model.
You can try, at your own risk, installing the 64-bit Pointing Device/Touchpad Driver originally supplied for the FW46M here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-FW46M
