hiii there i have a vaio fw11e it was very good and the battary too is good but suddenly it seems to be slower and then i found the battary charged till just 94%
i dont know what to do ???
thanks for ur replies
Two possibilities: -
1. The battery is faulty and you need to speak to Sony Support.
2. You may have the Battery Care Function enabled. This can be set to stop charging at less than 100% to lengthen the life of the battery.
You can turn this off if you prefer 100% charges: -
Start -> All Programs -> VAIO Control Center -> System Information -> VAIO Status Monitor -> Power/Performance Settings -> Battery Care Function
thanks for ur replying
the Battery Care Function disable i take a look at it
