Hi
I have a VGN-FS515E running xp service pac 3.Need to install/upgrade my Roxio programme and have to install Net framework 3.5.Everytime I try to there is an error in the installing. Have checked and have .net2 installed already. Any suggestions?
Hi adrutt and welcome.
Have you got .net3 installed already? Try installing this first
As a last resort some have had success by uninstalling ALL .net programs so that 3.5 has a clean machine to install onto. This tool will remove all traces of NET framework so if you have software needing a previous version you may have to reinstall the older version again.
You can download a .net framework cleanup tool here but read carefully to see if you are prepared to take this drastic step: -
http://blogs.msdn.com/astebner/archive/2006/05/30/611355.aspx
