I've upgraded my vaio firmware and sonicstage (SS) and vaio music transfer (VMT) also, but when I try to connect my vaio to the computer and run VMT or SS an error occurs - Atrac HDD does not work with this SS/VMT version.
It's odd 'cause I've downloaded the firmware and the software from same site:
http://www.vaio-link.com/vaiopocket/firmware/firmware.asp?l=en
Thank You
hi your atrac HDD is a VGF-AP1L isn t it ? perhaps it doesn t work because its not the latest version of SS or VMT i have a atrac HDD and i had a CD with my VGF-AP1L i have installed SS and VMT from the CD everything is OK SS is the 2.1 version try to update tis one and if it doesnt worf it perhaps come from ur USB port
I have the VGF-AP1. I've installed the software provided when I bought my vaio pocket. I install the updates for both programs (SS and VMT) and update the firmware of my vaio pocket and still says the same issue...The software used to work before the upgrade, I don't have a clue of waht's wrong...Can it really be USB problem?
Thank You
