currupted code 39 cannot play or load onto machine
alfredbeaven
Hi can anybody help
My notebook FX902P cannot play or load from my dvd player
It says currupted file code 39 drwtsn32.
any ideas please
alfred beaven :slight_frown:
4 REPLIES 4
rich912
Contributor
Hi Alfred,
The following involves changes to the registry and I recommend that you make a backup of you system settings before proceeding.
1.Click Start > Run and type: REGEDIT , and hit enter.
2. Navigate to - HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and locate UpperFilters, right click on this and select Delete and then OK.
3. Under the same Registry Key locate LowerFilters, right click on this and select Delete and then OK.
4. Quit Registry Editor and re-boot the computer, new registry values will be created that will hopefully cure the problem.
After you remove the Upperfilters value and the Lowerfilters value, you may possibly need to re-install your burning software – but not necessarily.
Go n-éirí an bóthar leat
alfredbeaven
Hi
RICH 912
Many thanks for your help ref code 39 cannot play or
or load programes.
This is working fantastic now your a genius
:slight_smile: :slight_smile: :slight_smile: :slight_smile: :slight_smile: :slight_smile: :slight_smile:
best wishes
alfred beaven
profile.country.en_GB.title
kee-lo_
Thank god I didn't reply, I was sure it was a bad lens
rich912
Contributor
I am pleased to hear that it worked Alfred:smileyhappy:
