Hi
I have just bought the TR5MP and have been configuring it. I have managed to get the bluetooth working with my mobile, and the dial up connection to the internet.
My problem is with connecting to my broadband box via my LAN and also to a wireless connection. I both cases I get a physical connection but my web browser (IE6) will not connect to the internet.
I have tried everything I can think of from disabling firewalls, rebooting, reconfiguring netwrok connections etc but nothing works.
Does anyone have any ideas?
Patrick
Are there other computers connected to the router?
If there are can you connect to them?
Can you get the network connected by using a network cable?
Have you set up your wireless SSID in the routers control pannel? Do you have a WEP key activated?
Which wireless router are you using?
Hi
I managed to sort the problem out and both the WIFI and the LAN connection work well.
The problem was that i had both connections incorrectly configured. They were associated with the Network Bridge when they shouldn't have been.
Anyway thanks for your help
Patrick
