Bad_Pool_Header
Damien
Bad_Pool_Header
Some of you guys may remember that I have posted on here about 5 times in relation to the blue Bad_Pool_Header screen i had problems with over the last year.
Well...i appear to have solved the problem!
I used to get the clue screen when i opened Nero. I would uninstall then re-install Nero and sometimes this would work, othewise i would have to do a re-format (Done this 3 times now)
Well it would appear that the problem is due to the Texas Instruments Memory Stick Controller.
If you download the Memory Stick Update from Sony Vaio Link, and update the driver, then this should solve the problem!
profile.country.en_GB.title
kee-lo_
Hi Damien
Thanks for your post, hopefully it'll help someone
