I'm a newby so forgive me if this question is naive.
I have been trying to record a 4 CD audio boxset onto a blank Memorex 4.7GB DVD+RW disc, using SonicStage software that came installed on my PCG-K215K with its Matshita UJ -820D CD/DVD read/writer, but have been unsuccessful.
Am I barking up the wrong tree?
Thanks for any info.:smileysad:
Yep you are
Unless I misunderstood, it's a DVD-A you want to make?
Remember copying CDs you don't own the copyright cannoy be discussed here.
Yep you are
Ahh I see, not sure you can do it, not many DVD writing apps allow the writing of DVD-A yet
Maybe Nero does this...
OK,
Many thanks.
You could just burn them as mp3s to a CD, most new DVD players will play mp3 CDs. As long as you use 256Kb/s Mp3s you will not be able to tell the difference
OK thanks,
So in MP3 format I should be able to get 4 CD's on 1 disc, right?
Easily
You should be able to get 250 tracks on 1 700MB CD, if the tracks are 3 mins long at 128kbs, in your case, 256kb tracks, you should get 125 tracks on a CD, so about 10 albums
If you only want the box set on there rip at 320kbps.
