- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Streaming issues with Sony kdl32w653a
Hi All,
Brought a new sony for my bedroom set up a few weeks ago. All has been fine since.
I tried streaming something from one of my networked hard drives, and it will work fine for a random time
(sometimes its 10 mins sometimes it 30 seconds) then i will get a message saying "Cannot connect to server"
I have tried this from 2 different media servers i have running.
I can stream stuff online to my tv with no problems( via youtube etc...), and i can stream from my media server to my pc with no problems at all.
I get good read/write speeds, tested and i can write to them at about 30mb/s and read at about 20mb/s.
My tv is wired in.
I have the latest software available.
Anyone else had any problems??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
I have theory here : The TV can only buffer a small amount of information, much less than a PC/Laptop. Try running the video file through a program called Bitrate Viewer. This should give you a little more information in regards to average bitrate and maximum bitrate.
Can you try playing the problem video file directly via a USB drive to the TV?
Also, the network cables. Are you using CAT5 or CAT5e or even CAT6? If you are using CAT5, I would suggest using CAT5e or CAT6 instead.
Cheers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks for that,
i have cat5e cables hooked into a gigabit switch.
But yer it would make sense it might be some buffering issue.
I ran bitrate viewer and one file i was trying (i have tried a few videos too) is average 5340kbs
but is maxing at 34000kbs. That might be the problem if the tele cant store that much?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
From that, im reasonably confident, its that "burst" bitrate @34000kbps. Try re-encoding the file, and set a max bitrate of say 10000kbps as a test (removing that variable). Now if that fixes it. You then know what the problem is. If that doesnt resolve the problem...well...back to the drawing board.
