- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
I have a Sony kdl-50w815b.
I've started using my TV for gaming but can't get the refresh rate to change from 24hz.
When I use Vsync its limiting my FPS to 24. If I don't use vsynch then i get major tearing.
I've tried messing around with various settings on my TV and using the below web page to measure the vsync value but nothing changes.
Discover your display's VSYNC refresh rate
This is the sony support page for my TV, but I'm having issue spotting anything do with the Hz. I can't even find what the default hz is. I cant believe its 24.
Support for KDL-50W815B | Downloads, Manuals, Tutorials and FAQs | Sony UK
This seemed like the most logical thing:
Home->Settings-> System settings -> Scene select.
There are various settings such as:
Auto
Auto (24p Sync)
Gaming
etc
I would have thought anything other than Auto (24p) would be a 60 hz signal, but what ever I change vsync still thinks my output is 24hz.
I've tried all the different HDMI slots in case that is the limit. Does anybody know if there a limits on the HDMI slots in my particular TV? Or how to fix my issue?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Its a PC 1080 resolution.
I found the issue. My display adpater properties -> monitor -> refresh rate was set to 24hz. Changing that to 60hz has fixed it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @bark01,
which device do you have connected (since you talk about V-Sync, I assume it is a PC)?
What resolution are you trying to use?
- Nic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
