My KDL-26U2000 has programs missing after install
profile.country.en_GB.title
90notout
Some programs are missing after digital install like 12 Yesterday.
How can I get the full quota of freeview on my TV?
4 REPLIES 4
Bravia55HX
you will need to check your aeriel, its most likely that its not up to digital standards and may need changing.
90notout
Thanks Bravia55HX9,  but I live in sheltered accommodation and I am one of 40 flats and probably connected to an aerial system rather than having my own personal aerial. According to my nephew.
Bravia55HX
90notout,
therein lies your problem then!, i would suggest that you find who's running the place there and ask if they are planning to upgrade the communial aerial there for a digital one because if they dont you will not be the only one suffering.
it is very likely that digital switchover has already happened in your area hence the loos of channels.
Catmambo
Contributor
Hi
Its likely this is the issue - maybe you could speak with whoever manages the block about having the aerial checked out as this would seem to be the cause.
Thanks
