Hi there
Interesting indeed. I would probably advise contacting Sony support on your issue and provide them with as much information as possible, as well as stating that it did work before the firmware update.
Before you do though, it would be best to factory reset the TV as well, as it does clear any problems that "could" occur. Add to the fact that support will request you do it as well
Excellent - Even better !!
Have fun.
Hi there
Unfortunately you cannot "roll-back" the firmware once a newer one has been installed. I believe the person managed to resolve this by resetting the TV back to factory default. Give that a go anyhow.
In regards to blutooth, the TV only supports blutooth mice not anything else.
In regards to NFC - see this lovely thread
In regards to wifi-direct - I dont suppose you have forgotton to put the TV into either screen mirroring mode, or accessed wifi direct via the TV;s menu system?
