General
Unique ID : 205520577751357869510250518556555037274 (0x9A9DD2D01A8C5A8484A8630950734A5A)
Complete name : D:\d\[Coalgirls]_Another_(1920x1080_Blu-Ray_FLAC)\[Coalgirls]_Another_01_(1920x1080_Blu-Ray_FLAC)_[BB945F6C].mkv
Format : Matroska
Format version : Version 2
File size : 1.50 GiB
Duration : 24mn 42s
Overall bit rate mode : Variable
Overall bit rate : 8 721 Kbps
Encoded date : UTC 2012-05-14 00:44:53
Writing application : mkvmerge v5.4.0 ('Piper') built on Mar 10 2012 13:34:39
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Attachment : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 24mn 42s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Title : 01 - Rough Sketch
Writing library : x264 core 122 r2184 5c85e0a
Encoding settings : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x133 / me=tesa / subme=11 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=12.0 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : Japanese
Default : Yes
Forced : No
Audio
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Duration : 24mn 42s
Bit rate mode : Variable
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Title : Japanese 2.0
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
Language : Japanese
Default : Yes
Forced : No
Text
Format : *****
Codec ID : S_TEXT/*****
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : :Intro
00:01:32.008 : :Opening
00:03:01.973 : :Part A
00:09:53.968 : :Part B
00:23:00.962 : :Ending
00:24:31.011 : :Previewhi, is there any way to play video like this?
Hi there
I would recommend Handbrake - Its a free open source program. It serves me well, but can be a little difficult to use first up.
Hi there
You will need to convert this file, specifically the audio codec, as FLAC is not supported. See the Supported codec list : HERE
what program would you advise for that?
Hi there
Thanks, i will try after work
