BBC Iplayer on a sony Bravia?
RÉSOLU
profile.country.en_GB.title
gekilda
Visiteur
Can uou get bbc iplayer on a sony bravia, and how do you do it?
1 SOLUTION APPROUVÉE
Solutions approuvées
gekilda
Visiteur
tanx boght a cable from maplins, much appreciated
Voir la solution dans l'envoi d'origine
5 RÉPONSES 5
TheKelman
Explorateur
Yes, but only if it is an  internet model?  Press "Home" button, then "Bravia Internet Video" then select it from one of the 28 Video On Demand apps.
gekilda
Visiteur
Hi, I selected video, it said no link,check cables,I dont know what it meant
TheKelman
Explorateur
It would probably be better if someone more expert than myself answered, but if you have an internet-capable Bravia, then you need to connect it to your home hub, either by 'hard-wiring' it which means getting a cable to run from your TV to your home hub (router).  You can buy a suitable cable from places like Maplins or even Currys, etc.  Or you could connect in a wireless way with a Sony 'dongle' which you can buy for around £60/70.  This plugs into the rear of your TV in a specific slot. (I hope this info is sound enough).
Catmambo
Contributeur
You need to give a bit more information like the model of your TV. Your manual will also clarify what services you get.
Thanks
gekilda
Visiteur
