Hi all..
I recently purchased the 40ex503, and when i went through the initial set up i chose NTSC instead of PAL,, can anyone please advise how i can change it to PAL?.
Message was edited by: Valmyre
After you did the solution above were you able to auto-tune in all available channels on your TV..:smileyconfused:
If not try this..
Go to the Home menu..
Then browse to Settings..
Followed by System Settings..
In the System settings menu click on General Set-up, followed by Factory Settings..
Hi Valmyre,
welcome to Questions & Answers..
Try this..
In the System settings menu click on Auto Start-up..
hi Thalamus.. thanks for your quick reply
and for the welcome...
I did try the auto startup but it didnt give me the option to choose ntsc or pal...
If not try this..
Yes after i did the auto setup i was able to auto-tune the channels , but the option for choosing PAl was not there..
If i use the factory settings will it mess other things up?
If your Bravia is working ok & you are able to view the TV channels via an aerial then your TV is set up correctly..:smileywink:
Have fun & enjoy your new Bravia..:smileyhappy:
