Hi....... Mine is doing exactly the same.:smileysad: Have yo solved the problem?
Regards, Dexan
My xperia tl is having same issue, just started day before yesterday. now my wife's xperia tl is doing same this morning. had success yesterday resetting my phone and started charging, held charge until night. plugged in overnight and is drained to 25% battery. i did not let the battery fully discharge any time. the phone is 1 1/2 years old.
I have the same problem, even bought a new battery and took it to specialists but so far nothing happening and it's like it just died but, when i bought the new battery it turned on with the power from the new battery but on exhausting the power it has gone dead again. Anyone with any final solutions?
I had the exact same problem with my XPERIA Z5 compact ... And solved it!
Battery was at 3%. Not charging. I decided to reboot, thinking it is a bug.
It didn't start again. Tried all chargers, cables. Power+volume UP, Power+Volume Down.
Called Sony support Switzerland. Amazing people. Best customer service ever.
"Sir, do you mind removing your SD card, your sim card, and trying to charge it?"
I worked. Instantely.
Hope this helps.
Thanks FrankStw
Amazing this worked for me as well! Wan't charging with wireless jacket or direct usb (no red light). After removing sim and sd card the light came on after a couple of seconds!
Thanks!
The same problem happened to me, I removed the Sim and SD Card then charged it for about an hour when the red light lit up and my phone started to work again. So the Swiss solution seems like the best for me, hope it is gonna work in the future.
I might have to order a new charger though.
