- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
When i press anywhere on my touch screen shows that rectangles. When i want to unlock it or scroll down shows first this rectangle and the i have to swipe with two fingers to unlock! When i want to press a button it shows again this rectangle an d then i have to press two times to press it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Do you have any development options enabled?
Check if you have something called Development options under Settings. If yes click it and turn it off.
If you do not have dev options in your settings menu try booting your phone in safe mode to see if this may be caused by any installed application.
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No have disable the developer settings and restarted the phone but nothing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Did you also try safe mode like suggested by Johan?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
again the same problem!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This is strange,it sees the outline for widgets,buttons etc.I suggest you try a software repair.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Software repair!?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes,it means an application will reinstall software on your Xperia M.You have to backup your files because it will erase internal memory:
http://www.sonymobile.com/gb/tools/update-service/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I tried to disable some apps and when I disabled talk back it fixed! Thank you!
