Screen will not rotate at all
Langton92
When turning my phone to landscape mode the screen does not change whethee i am watching a video oron the home screen please help!!
Tags (1)
Jonas
Master
Hi @Langton92, sorry to hear about this. Slightly_frowning_Face
There isn't that much that can be done since the device has reached it's end of support, but I would recommend that you try and restart the device in safe mode. This way we can see if a third party application is causing the screen to not rotate correctly.
If you could also double check which Xperia L model you have that would be great since the Xperia L was released in 2013 and you may have a newer model. You can find the model number in Settings > About phone.
Thank you.
