- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
July 2013
July 2013
Sony RDR-hxd890 Signal help
Hello , i recently bought this dvd recorder but can not pick up any channels and have 0% signal strenth , can anyone please help with this do i have to have firmware or do something else in the settings ? If so how do i sort this out ?
Anonymous
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
July 2013
July 2013
Hi there
If you have 0% signal strength, you will not be able to pick up any channels.
A couple of things to check out is -
- Check that you have connected all cables correctly (in your case, the aerial cable)
- Check that the condition of the aerial cable is good (may be replace it with another one, at least for a test)
- Connect another device to the aerial (ie a TV) to see if you are getting any signal at all. (If not, you may need to have a look at the aerial itself)
Cheers.
