Netflix
kkmtz2011
Netflix
I have an bdp-s185 the Netflix app was on my Blu-ray player a couple months ago and now I can't find it is there a way to add it back?
Mick_D
Moderator
Hi @kkmtz2011, welcome to the community.
These players came with a set of pre-loaded apps designed to run on the OS. Unfortunately, this means that it’s not always possible to run new apps, nor would your old Netflix app work now even if you had it, as older players are unlikely to support newer versions.
You could try getting hold of a Chromoecast, Fire Stick or similar, that would do the job.
Mick
