- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Help! No picture from Bluray player! BDV-N7100W
Hi!
installed my new home cinema, got picture at start, did all the setup.. but now after, i cant get picture either when i have a blu ray disc in or to access the setup system, the TV is just getting black..
any suggestions?
i get sound, but no picture!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
A couple of suggestions for you:
- If you have connected it up via HDMI cable, if the cable is an older one, you might want to think about replacing it.
- Try turning OFF the TV and N7100W from the powerpoint at the wall. Leave off for a couple of minutes and switch it all back on again.
- Try pressing the [Play] button and the [VOL - ] button at the same time on the main unit itself. Hold down for more than 5 seconds (ie 10 seconds). This will reset the output video resolution of the unit to its lowest setting. So IF it works, you need to look at the resolution settings.
Hope that helps
Cheers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've tried to switch HDMI cables, i've use 3 different.. still dont work! im going to try the last of your suggestions.. if that dont work, what to do? is the blu ray player broken or what?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
What type of TV do you have? Is it an older TV (ie something like HD Ready?)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Well thats, that idea out then. Im assuming that you tried the third suggestion of the play and vol - buttons and it didnt work? Unfortunately im out of ideas, and your probably going to have to contact Sony Support. Unless someone else has any other suggestions.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No problems anyhow. Good luck with everything anyhow.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
looking quickly at the specs for the unit, i believe your problems lie within the set up, can you get the menu screen up?, if so go through all the settings again and set screen size etc etc, i am convinced tha.ts where your problem is
