Just hooked up a new PSHX500 Turntable to my hi fi system and every vinyl record I put on the turntable comes out distorted sound through the speakers - if I play anything else through the hi fi system CD, etc the sound is fine.
Would appreciate any suggestions as to what may be causing this? Could it be:
1/The weight of the arm - the counterbalance and anti skidding were set to 3 as recommended in the set up manual
2/ I connect the earth up to the Hi Fi amplifier .. maybe it doesnt need it.. though it is not a buzzing earth distortion sound - but an 'overload cooked' sound at all volumes loud and soft
It could be the surface you have the turntable on, try moving it around and also try connecting it to another speaker if you can.
